Results 1 to 9 of 9
Thread: My pool
    My pool
    I am a new pool owner and I have done just about everything that the pool person said and evrytime I do something they tell me it messes my pool up more. I have added the bleach for the pool and my ph is way down and it says I need to add acid how long should I wait in between
    10,400 gallon/above ground pool/sand filter
    Re: My pool
    Welcome to TFP!
    We can help you get things working correctly and the water sparkling, but we need more information. Could you post a complete set of water test results and describe how the water looks?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My pool
    Welcome to the forum
    Post a full set of test results and we can help you.
    BTW, if the pH is low, then you do not need to add any acid as acid will lower pH more.
    You're done SLAMing when:
    Re: My pool
    I have a 30,000 gallon pool the looks greenish but can see it clear in some parts. the chlorine is at 3.o and the ph is so low the counting drops dont even bring it up i have counted 30 drops it below 6.8 and my alkalinity is at 90
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: My pool
    How are you testing your PH? Your reference to 30 drops doesn't make sense. Are you sure it is a PH test?
    Re: My pool
    Quote Originally Posted by woodyp
    The taylor 2006 comes with acid/base demand. He might be doing the acid demand test when he should be doing the base demand test..
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Re: My pool
    I bought a pool tester from home depo and it says fill large vial with pool water to top marked ph and acid demand than add one drop of solution 4 which says indicator solution use 1 drop for chlorine neutralizer than add 5 drops of solution wihich is red indicator solution for ph test than says compare reading which it come out to below 6.8 so how do i get my ph level up
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My pool
    Use Borax to raise pH. You can use the PoolCalculator.com to figure the doses.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My pool
    Welcome to tfp, stacyjoe
    As others have mentioned a full set of test results would help us help you. Here is a useful link to get started: http://www.troublefreepool.com/what-...ns-t10341.html
