Results 1 to 18 of 18
Thread: Cloudy water during swim party.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    We had a pool full of kids today and my water got very cloudy. I had the same problem last summer with cloudy water with high swimmer load. It got bad enough today you could just barley make out the main drain.
    Test results from this morning before party
    TC 7
    CC 0
    Ph 7.4
    Cya 40
    TA 60
    CH 400
    Test results after the party
    TC 4.5. (Stenner pump added about .5ppm during party)
    CC O
    Ph 7.4
    The two speed pump has been on high all day and the ozonator has been on all day. The pool used alot of chlorine during the party, but I started with it a litte high and it stayed within range.
    Kids have been out of the water for about two hours now and it already looks much clearer, but not all the way back to normal.
    We have groups of kids in the pool frequently - anything I can do different to keep it sparkling? It is not cool to have sparkling water when it is the family swimming but have it cloudy when I'm trying to show off to company.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cloudy water during swim party.
    Maybe the large number of swimmers stirred up dust on the bottom. Is your pool painted?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I'm thinking along the same lines as JohnT. How frequently and thoroughly do you brush? I know my pool can look pristine, and then I grab the brush and suddenly it's not so clear. I'd give it a thorough working over a couple days before the next party, so there's less sticking to the walls for people to rub off.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    It is plaster and built last spring. Polaris runs every day but I rarely brush it.
    If it was dust or etc on the bottom wouldn't it get stirred up when fewer kids are splashing around with every day swimming?
    Jandy 2 speed pump
    Kids provide a lot of oxidizable products that can have an adverse effect on water quality. Things such as urine, suntan lotion, dead skin, hair etc. will cloud the water until the chlorine and filter have enough time to clear the water. Having kids shower before entering the pool and providing a convenient bathroom can help reduce the contaminant load.
    Support the site
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Quote Originally Posted by JamesW
    Gross - but true. Doesn't the chlorine almost immediately oxidize the contaminates? I thought the immediacy is what made chlorine the best sanitizer while other options were not safe because of the time to oxidize?
    Jandy 2 speed pump
    If there are enough people swimming, chlorine alone can't quite keep up. Some cloudiness after a particularly large number of people have been swimming is normal. Extra chlorine and extra pump run time will both help.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    This afternoon we are having my daughters 5th birthday party. That means lots of 5 year olds in the pool.
    The pump has run for the past 24 hours. I've swept the pool several times this week (plus Polaris every day), and FC is higher then I normally keep it.
    I hope it stays crystal clear!
    Jandy 2 speed pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Do let us know how it goes, and good luck
    Ike
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Not just kids. Adults bring suntan lotion, dead skin, hair, etc into the pool just the same.
    "Ah-ha!" I hear you say. But adults don't pee in the pool!
    Want to bet?
    A new survey by the Water Quality & Health Council indicates that 1-in-5 adults admits to urinating in public pools.
    http://www.wsmv.com/story/18678229/surv ... es-in-pool
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Mostly a success. The water lost its sparke but didn't get so cloudy you couldn't see the bottom.
    But I used up a ton of chlorine. At the start of the party my FC was at 7ppm. An hour in I checked and it was down to 3 so I turned on the Stenner to bring it back to 5ppm, an hour later i chrcked again and it was still at 3 so I ran the Stenner again. During the four hours of the party I added 120 ounces of 6% and at the end of the party the FC was at 3.5ppm.
    That is alot of pee..........
    Jandy 2 speed pump
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Quote Originally Posted by gboulton
    Want to bet?
    If one in five adults admits this - you know at least twice that many really do.
    I wish that stuff from the movies that turns the water pink when sombody pees was really available!
    Jandy 2 speed pump
    Oct 2011
    Charlotte, NC
    120
    LOL at the kid in the green shirt getting ready to get shot in the head at point blank range. Got to love kids pool parties!
    8000 gallon outdoor inground vinyl. Sand filter, Hayward 1HP.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Quote Originally Posted by texasdad
    Perhaps...but that picture makes me think it was worth it.
    -Gordon
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    texasdad,
    We too just had a pool party today. 20 kids ranging in age from 14 to 5. The water was sparkling before they got in. After everyone left, water is now cloudy and I can just barely see the main drain 7ft deep.
    FC 8 (last night it was 11)
    CC 0
    pH 7.2
    TA 90
    CYA 40
    With these numbers, I was planning on shocking the pool so it would get a jump on the "oxidizable products".
    Is that a good idea? (We have a sand filter, using Zeosand.)
    Thanks for your input.
    Mariane
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Quote Originally Posted by mariane
    CC 0
    pH 7.2
    TA 90
    CYA 40
    Bumping up the FC to about 10 to 15 ppm would probably help.
    Support the site
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    texasdad,
    CC 0
    pH 7.2
    TA 90
    CYA 40
    Mariane
    I haven't ever shocked after a party - and have never had an algae outbreak. I think the thing that helped mine the most running the filter and polaris (or sweep if no polaris) for extra time before the party and keeping the chlorine a little higher then normal. I checked mine during the party and added because it was disappearing quickly.
    We had a large crowd in our pool every day last week. A Birthday Party on for my daughter on Saturday, a Church party on Sunday, and then Monday through Friday our pool was used for swim lessons - our daughters got free lessons since it was our pool that was used. But there were about 40 different kids in and out at different times all week...... Used up lots of chlorine but all went well.
    The pool always clears up back to normal within an hour of everybody getting out.
    Jandy 2 speed pump
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    okay, great, and thanks. ;o)
    I'll be looking forward to sparkling water returning tomorrow.
