Thread: older astral multi port valve
    My valve is very difficult to turn, I suspect it has sand in it. I pulled so hard on it that now the head came off. It used to be attached by a small white clip on the side. Now I look at the valve and wonder can I replace the spider thingy and somehow clean the sand out of it, or does it sound like I need the replacement.??
    Anyone go thru the problem with an old worn multi port valve?
    thanks
    Matt Headd Syracuse, NY
    24 * 5 intex above ground pool sand filter swg
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: older astral multi port valve
    Maybe the roller pin that the handle pivots on or the spring underneath just needs greasing? The white clip should be just a snap/lock mechanism to engage when it is screwed all the way down and in the right position. I'd sure replace the gasket first and see how it works.
