Ok .... after a couple of years of knowing i should go BBB i bit the bullet and bought a kit.
Here are my test results ... i am in upstate NY ... pool is 63 degrees ... i opened a day or two ago, added water to get to the right level and a gallon and a half of bleach last night.
The cheesy test strips looked good this morning.
Followed the directions and got the following results
daily test showed chlorine between 1 and 2 and PH at 7.2
TF100 results
CL=1.5
CC = .5
TCC = 2
TA = 110
CH - 325 (vinyl)
CYA - i couldnt get a reading / tube was full
so if i look at the calculator i see where i can put my results... what exaclty do i use as the goal?? .... how do i look overall ... what should i add tonight??
i promise i'll figure this stuff out
TF100 results
CL=1.5
CC = .5
TCC = 2
TA = 110
CH - 325 (vinyl)
