Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: First Test! .... what next?
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Ok .... after a couple of years of knowing i should go BBB i bit the bullet and bought a kit.
    Here are my test results ... i am in upstate NY ... pool is 63 degrees ... i opened a day or two ago, added water to get to the right level and a gallon and a half of bleach last night.
    The cheesy test strips looked good this morning.
    Followed the directions and got the following results
    daily test showed chlorine between 1 and 2 and PH at 7.2
    TF100 results
    CL=1.5
    CC = .5
    TCC = 2
    TA = 110
    CH - 325 (vinyl)
    CYA - i couldnt get a reading / tube was full
    so if i look at the calculator i see where i can put my results... what exaclty do i use as the goal?? .... how do i look overall ... what should i add tonight??
    i promise i'll figure this stuff out
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    30,426
    Re: First Test! .... what next?
    Yeah, it'll get easy soon. If you still have time tonight, put a small jug of clorox in the pool so you'll have some FC tomorrow.
    Tomorrow, go to HD,Lowe's or Walmart or Pool store and get powdered CYA (cyanuric acid or stabilizer) Using the pool calculator, figure enough to get your pool to 40ppm and buy it.
    Place it in a sock tied in front of one of your returns and it will slowly dissolve...may take a while.
    Then tomorrow evening, test your FC again (do it with the daily test as it will probably be close to zero) and add enough CLorox to get you to 5ppm......pump running.
    That's pretty much it. Your numbers are looking pretty good and I see no real need to adjust anything else right now. You will have to add Clorox daily or every other day as you will probably lose about 2ppm each day.
    Nov 2011
    Albany, NY
    495
    ok .... i was able to add chlorine last night
    looking online at wally world it appears that the cyanuric acid they sell is part of the stabilizer ..... is that the correct stuff?? i am almost positive i have stabilizer left over from last year... would that be acceptable to use??
    Haywood Sand Filter
    Vinyl Liner
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by ship of fools
    Yes, Wallyworld sells CYA, a/k/a conditioner or stabilizer. Just read the ingredients. It should be at least 96% cyanuric acid. And yes, you can use your leftover CYA.
    You are now in control of your pool.
    You're done SLAMing when:
    Nov 2011
    Albany, NY
    495
    If i am reading the pool calculator correctly i need to add 112 oz by weight of stabilizer.
    The leftover stuff is 100% CYA so i assume i can use that ......
    If my math is correct that is roughly 1/4 of a pound??
    I had a 4 lb jar from last year that is about 3/4 full so i only need to use roughly 1/12th of the jar??
    Haywood Sand Filter
    Vinyl Liner
    30,426
    1 lb = 16 oz.
    Nov 2011
    Albany, NY
    495
    1 lb = 16 oz.
    duh .... been a while since i studied weights and measurements
    so 7 pounds total?? i assume it is ok to mix brands??
    Haywood Sand Filter
    Vinyl Liner
    30,426
    Yep!
    Nov 2011
    Albany, NY
    495
    OK ..... i added 7 lbs of cya yesterday and then got home too late to do much but i added half of a 182 oz bottle of bleach.
    Here are my test results now - i included the 1st test in parentheses
    PH = 6.8 (7.2)
    CL = 6 (1.5)
    CC= 0 (.5)
    TC = 6 (2)
    TA = 115 (110)
    CH = 300 (325)
    CYA = 38 (0?? could see dot with tube full)
    the only place i see to get PH is with the simple daily test??
    the water is not quite crystal clear... i can see the main drain very clearly but it seems like it may be a touch cloudy
    so far so good with the test kit .... seems easy enough
    if i am reading the pool calculator correctly i need to add
    134 oz washing soda or 267 oz borax (i have the mule team borax)
    1/2 lb cya
    sound right? .... any suggestions / alterations??
    thanks!
    Haywood Sand Filter
    Vinyl Liner
    Jun 2011
    Long Beach, CA
    2,790
    That much borax will be fine, but leave the CYA alone for now. CYA can take up to a week to fully register on the test. You might consider bringing the FC up to 15 to shock the water since it is not clear. Also, make sure you pass the OCLT, overnight chlorine loss test found in pool school.
    Nov 2011
    Albany, NY
    495
    Today's update
    here are my readings from a 730 PM test with yesterday 9 AM test in parentheses
    i added 76 oz of borax last night versus the 267 recommended
    simple test
    CL = 5+- 5+-
    PH = 6.9 - shade darker than 6.8 (6.8)
    FC = 5 (6)
    CC = .5 (0)
    TC = 5.5 (6)
    TA = 105 (115)
    CH = 290 (300)
    CYA = 41/42 (38)
    If i understand things correctly i am looking pretty good with the exception of the need to raise my ph ..... the calculator says to add 202 oz borax so i am thinking about 2 boxes which would be 152 oz
    sound good??
    why would my cc go up?
    is a drop of 1 on my TC readings ok for a 24 + hour period?? ...it was cloudy and i had the cover on all day
    the pool looks pretty darn clear right now
    Haywood Sand Filter
    Vinyl Liner
    Butterfly's Avatar
    South Carolina
    10,045
    Yes, use borax and get the pH up ASAP.
    Have you done an OCLT?
    ETA: CC increased? Pool cover on pool?
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Butterfly
    i have not done the oclt - but if i tested at 9 am yesterday and had fc of 5 and then had fc of 5 today without adding chlorine isn't that essentially the same test??
    the pool cover was on the pool .... would that cause the cc to increase??
    Haywood Sand Filter
    Vinyl Liner
    Butterfly's Avatar
    South Carolina
    10,045
    Yes, the pool cover prevents CC from being nuked by the sun.
    Nov 2011
    Albany, NY
    495
    today's update .... i think i am getting close to good numbers??
    i added borax each of last two days .. stabilizer the day before
    today (yesterday)
    simple cl 5 (5)
    ph 7.8 (6.9)
    fc 3.5 (5) why is this different than simple test reading??
    cc 0 (.5)
    tc 3.5 6
    ta 110 (105)
    ch 240 (290)
    cya 31 (41/42)
    calculator says to add some bleach (1/2 jug or so) plus muriatic acid to lower ph .... i assume i should skip muriatic acid and do the bleach
    is that much chlorine loss normal? .... cover off ... decent amount of sun today
    why would cya drop so much?
    what is causing ch to drop?? ... i know its ok at this level and maybe even a good drop ... we had rain last night
    thanks .... testing is now a peice of cake ... i am going to test my neighbors who had crazy readings from his pool store test
    Haywood Sand Filter
    Vinyl Liner
    Nov 2011
    Albany, NY
    495
    do i need a little more cya?
    Haywood Sand Filter
    Vinyl Liner
    Butterfly's Avatar
    South Carolina
    10,045
    Your CYA is in the recommended range. If you seem to lose too much FC daily, you should consider raising the CYA a little.
    Nov 2011
    Albany, NY
    495
    any chance someone could address this??
    butterfly was kind enough to answer my cya question but i would really appreciate someone addressing this post
    thanks
    today (yesterday)
    simple cl 5 (5)
    ph 7.8 (6.9)
    cc 0 (.5)
    tc 3.5 6
    ta 110 (105)
    ch 240 (290)
    cya 31 (41/42)
    Haywood Sand Filter
    Vinyl Liner
    22,551
    First off, the OTO test is good for a 'go/no go' test for chlorine but not very good for getting an accurate reading. The FAS-DPD test is the best to use when you want to know what the FC & CC really is.
    What is the pH you're targeting in the Pool Calc? It's lower than 7.8 or the Calc wouldn't suggest you add acid. Don't worry about it right now.
    Actually 1.5 ppm per day is less than normal. About the best most people can get is 2 ppm per day loss.
    The CYA difference is a testing discrepancy. Don't worry about it, it's within the accuracy of the test.
    CH is the same, a testing discrepancy.
  20. Back To Top    #20
    Nov 2011
    Albany, NY
    495
    thanks
    so overall would you say i am in pretty good shape now??
    at this point in time am i ok to do the daily test and then add chlorine as needed and borax if needed then once a week do the whole gamut??
    or should i do the better chlorine test daily?
    i am pretty comfortable with everything so far and the pool is sparkling and just plain beautiful
    Haywood Sand Filter
    Vinyl Liner
