Thread: ? about pool calculator
    Dec 2007
    NW Georgia
    56
    May be asking a dumb question here but when using the pool calculator to determine the correct amount of chems to add to pool to balance water. What does it mean when it says add x amount of muratic acid or CYA by volumn? Please explain in layman terms thanks.
    41K L shape Vinyl IG, 2.0hp Jandy stealth pump, 300lb sand filter, Autopilot Dig-220 SC-60 cell, Dolphin Oasis Z5.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: ? about pool calculator
    Quote Originally Posted by Simearl
    Some chemicals are measured by weight, and some by volume, and some by both. The term "by volume" means to use ounces as in 8ths of a cup, where the term "by weight" would mean to use ounces as in 16ths of a pound.
    Dec 2007
    NW Georgia
    56
    The pool calculator said I needed to add 187oz by weight of stabilizer. Do I just add 187oz or do I need to do a calculation then add stabilizer?
    With stabilizer, as with many of the chemicals you add to a pool, it is better to add about 3/4 of the total amount and then retest to see where you are and adjust from there. It is much easier to add stabilizer than it is to take it out, so you want to approach the goal in two or three steps instead of all at once so you don't overshoot. Remember that stabilizer can take up to a week to dissolve, so wait a week after adding some before retesting.
    Dec 2007
    NW Georgia
    56
    Thanks for the info. I will be working on getting the water balanced this weekend.
