Results 1 to 8 of 8
Thread: whats my ph
    whats my ph
    [attachment=0:3ppjix2a]0519121457.jpg[/attachment:3ppjix2a]can you tell me were to go with this pretty blue ph test
    21 foot round above ground, 1200 gallons, 1 HP pump, 15 inch Hayward sand filter then a cart filter, TF-100 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Re: whats my ph
    From the looks of the chlorine, you're somewhere around 20 FC. Which does weird things to the pH test. Which is also why we recommend adjusting pH before shocking and then ignoring it.
    Re: whats my ph
    thanks I guess I should not be chasing it then, trying to shock enough to get clear opened in Feb and still not clear yet.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: whats my ph
    I'll bet your Cyanuric Acid (CYA) level is near zero. It seems that the high Free Chlorine (FC) interference with the pH test doesn't happen very quickly when there is CYA in the water, or more technically when the active chlorine level is lower. Even our shock level recommendations with an FC that is around 40% of the CYA level is equivalent to around 0.6 ppm FC with no CYA whereas your FC with no CYA would be much much higher than that.
    I'd be a little careful not to shock with too high an FC if your CYA level is truly near zero. The active chlorine level will be very high and you'll want to be careful with what I assume to be a vinyl liner for your above ground pool.
    Re: whats my ph
    I ran out of the reagent for the CYA but the pool store says it is around 25, the only other problem I have is a low TA, lowered my chlorine level and got a good reading on the PH thanks, did not know the chlorine affects the PH reading, learn some thing new every year. Thanks again
    Re: whats my ph
    Is that the color the sample turned right away, or did it start out closer to red/orange and slowly turn purple?
    If you can get an accurate CYA level, that would help determine how much the FC interfered with the test.
    Support the site
    Re: whats my ph
    that was the immediate results the pool store says my CYS is 25
    22,544
    Re: whats my ph
    Hey Ray, Keep in mind that the pool store is notoriously bad on getting the CYA test right. I'd get more CYA reagent and do your own test. Then you'll know for sure what's going on.
