Thread: Faster Dissolving Cyanuric Acid
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    I have 0 CYA and a DE filter I need to backwash frequently (after clearing algae on opening.)
    I just read this entire thread...
    It seems that everyone agrees that CYA takes up to a week to fully disolve (even after the initial chrystals have disolved.)
    Why can't I just put the CYA chrystals in a 5 gal bucket of water, let it sit for a week, and then add it to my pool?
    Would my CYA be sufficiently "disolved" using this method?
    -Ken-
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Re: Faster Dissolving Cyanuric Acid
    If you put the CYA in a bucket of water it simply won't dissolve, even after a very long time.
    Mar 2007
    San Rafael, CA USA
    12,082
    Cyanuric Acid is slow to dissolve, but exposing it to circulating water as in front of a return flow speeds up the dissolving rate. If you don't care about spending more money and just want CYA that dissolves quickly, then you can buy Natural Chemistry® Instant Pool Water Conditioner which is the sodium salt of cyanuric acid (i.e. sodium cyanurate) in a slurry so dissolves much more quickly. It's about twice as expensive as pure CYA for the same CYA level, however.
