Thread: gas heater on an intex pool?
    Is it possible to attach a gas heater like a Hayward onto a large intex pool? Anybody heat theirs? Solar not an option. Thanks.
    Inground Concrete Pool With Fiberglass Walls (20,000 Gallons), Hayward .75 Super Pump, Hayward S200 Sand Filter, Pentair IntelliChlor IC40
    Re: gas heater on an intex pool?
    Welcome to TFP!
    It is possible to use a smaller gas heater on an above ground pool, though there are a couple of things you need to watch out for. First, you need to make sure your current pump has a high enough flow rate to keep the heater happy. The smaller Index pumps aren't usually enough. Second, you need to run rigid pipe for at least a couple of feet from the heater. Otherwise you run a risk of the heater melting the hoses.
    Thanks Jason. It's a prety large Intex so it came with a good size pump. I may upgrade that one however if I add the heater.
    Jason - are you saying you can't use "real" flex hose from the heater, or just that you can't use the Intex hoses?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
