Thread: Pool Pump Cover
    Apr 2012
    South Dakota
    87
    Pool Pump Cover
    I have a Rule 1800 pool pump cover that doesn't pump water off the cover. When I plug it in i can hear it run for a second and periodically it will run for a second. The leaf protector is completely submerged. I took the leaf protector off and cleaned it out which wasn't clogged and I could see the impeller spin when I plugged it in.
    Bad motor?
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    Re: Pool Pump Cover
    There are two things that could be happening. First, that pump starts up for a moment and checks to see if it is pumping any water or not. If there isn't any water it will turn it's self off again. You might be mixing up the fact that it turns off automatically when it is actually working because there is no water at that particular moment. The other possibility is that the pump can no longer detect water correctly and thinks there isn't any water even when there is, in which case it needs to be replaced.
