Results 1 to 8 of 8
Thread: Saturation Index with Vinyl Liner Pool?
    May 2012
    Jackson, TN
    24
    In my education process to have total control over our pool, I've been reading up about CSI and how it changes with TA, CH, pH, and water temp.
    My numbers are currently:
    FC 4.0
    CC 0.0
    pH 7.6
    TA 70
    CH 190
    CYA 55
    SWG @ 20% output
    Water temp is around 83deg and climbing daily so my CSI is right at -0.1 and should end up right at 0.0 once we get into full summer weather so I'm not changing anything right now.
    I know the CSI is important with gunite pools and such but does it really matter with a vinyl lined pool?
    Still learning and absorbing all the great info on this site!
    In-ground, vinyl pool, 26,000 gals
    Hayward Sand Filter, Aquarite SWG, Hayward Ecostar Pump
    Re: Saturation Index with Vinyl Liner Pool?
    With a vinyl liner pool it isn't usually worth even thinking about CSI unless you have high CH fill water and high evaporation rates. Most people can simply keep their levels within the recommended ranges and leave it at that. That said, no matter what kind of pool you have you don't want the CSI getting above about 0.5. That will lead to calcium scaling. If you have a vinyl liner pool it is completely fine to have CSI very negative, and preferred if you can keep it at least a little negative.
    May 2012
    Jackson, TN
    24
    Thanks Jason. That's what I was thinking.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I'm glad I read this, my csi is -0.3, but I was thinking it shouldn't matter with a vinyl pool. Thanks
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Apr 2015
    Knoxville, TN
    64
    How in the world is your pool that warm? I'm in east tn and my pool is 55 degrees.
    Sand filter
    Salt Generator
    25000 gallon IG Vinyl
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by Rere View Post
    Check the date on that post.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Apr 2015
    Knoxville, TN
    64
    Quote Originally Posted by Saturn94 View Post
    Well I'm a dork! Newbie mistake.... Can you tell I was jealous of those warm temps just a few hours away?
    Sand filter
    Salt Generator
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Our pool hit 82 yesterday....solar cover and Savannah Georgia sun.
