Results 1 to 12 of 12
Thread: start up ?
    start up ?
    opened up yesterday... water comong out of jets is "cloudy like" and a soapy like film is on the top?
    Algae? Time to shock as per pool school?
    thanks in advance...
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    30,514
    Re: start up ?
    Everything related to pool water condition has to start with test results. Can you post those up?
    Re: start up ?
    temp 65
    fc 16
    cya 40-45
    ph looks ok as does akalinity
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Re: start up ?
    Saying "ok" doesn't really tell us what we need to know, we really need numbers. Your concept of "ok" and ours are quite likely to be different.
    If your only issue is a "soapy" film, then a couple of days at elevated FC levels should take care of it.
    Re: start up ?
    I'll do a drop test tonight and sunday am
    thanks
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Re: start up ?
    tc 11 ( did a drop test last night, it held)
    cya 45 just added per pool calculator
    ph 6.5 just added borax ( but not enough per calculator, have to get more)
    TA 60 just added baking soda per calculator
    so anyway.. I was using my returns as suction overnite and my bottom drain as a return , pool is practically crystal clear. THEN i switch it back to suction from bottom drain and skimmer and returns as normal and i get this cloudiness that comes out of the returns?
    Have at it...............
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Re: start up ?
    oh ps.. it dissapears fairly quickly
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    30,514
    Re: start up ?
    Surely I don't understand this correctly. Are you reversing the flow of your system?
    Re: start up ?
    yes i have a 4 way valve and a 3 way one where i can do that... prob would not do it if i built another, the theory was to be able to skim the warmer water off the the top and push it out the bottom with the warmer water being insulated at the bottom.... The heat pump did take it from 65 to 85 in about 24hrs. its was 85 today and 55/60 overnight
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    30,514
    Re: start up ?
    Yikes! I can't think of anything good coming from that!
    I think I would stop reversing the flow and not do it again. Since that caused the cloudiness (although I don't know why) I don't think it serves a purpose so why do it?
    Re: start up ?
    i hardly ever use it, but would have to wonder why reversing it would cause anything to happen. Its still just water into the pump, through filter then heat pump and out into pool as ususual.
    anyway , thanks for the input
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Re: start up ?
    still gets cloudy....
    1st FC 5 CYA 70 ph 7.5 ta 90
    pool looks great, clear. If i shut off filter then start it back up or when it first starts, pool gets cloudy, clears up in 10 minutes or so.... what the heck is causing this.. ITS EAR RAH TATE ING! lol any help will be appreciated......
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
