Thread: Foamy water
    Foamy water
    Hello, just want to start off by saying I LOVE THIS SITE! Been using it for 3 years now and never needed to post because the answers were always right here. With that being said, I am having the worst time trying to open my pool this year. So now I find myself in need of some help. I know I have come to the right place. After having a pump motor failure, I was lucky enough to be able to pick up a brand new system. Got it hooked up and started filtering and now I have foam in the pool. I understand it is sucking air from somewhere, I am just baffled as to where. No leaks we can see. My question is could it be coming from the skimmer box somehow? Really want this foam issue eliminated. Thanks in advance for any advice.
    10000 gallon AG, Hayward filter with variable speed pump. TF100
    Feb 2008
    Denton, TX
    5,061
    Re: Foamy water
    Welcome to TFP!
    Can you give us a full set of test results to look at?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Foamy water
    Did you add any algaecides? They can cause foam.
    Is the foam coming out the returns, or just on the surface?
    Re: Foamy water
    Foam is just on the surface. No algaecides. Under the impression thats a no-no.
    Re: Foamy water
    Also can't really give any test results as I am shocking, and just added cyanuric acid, etc... to open. Don't think they would be accurate.
    Re: Foamy water
    Foam is usually the result of the combination of a thin layer of organic oil on the surface, often from pollen, and a source of air bubbles. Eliminate either of the two and the foam will go away. Chlorine will normally break down organic oils, though sometimes that process can take a while. Bubbles can come from several places. If they are coming out the returns you so see if you can fix that. Other sources of bubbles are not usually worth worrying about.
