Results 1 to 7 of 7
Thread: yellow area under skimmer and return flow
    Sep 2009
    Alabama
    22
    Please help! Water was clear but yellow strip bottom side of pool under the skimmer and return flow. The only other issue was what looked like lines of brown dirt from center in a couple of places. This brown stuff scattered like dust when brushed. Thought it was mustard algae. FC was 4, CC zero, ph 7.8, CYA 40, alk 90. Added 'yellow clear' and one gal of 6% bleach. Next day, yellow gone, water still crystal clear but now FC is 2 and CC is 10. We have NEVER had CC higher than FC. From the info I've read, if CC is high, then there's still something in my pool, is that right? Do I need to add bleach to shock level (according to pool calculator, I'd need to add 392 oz of bleach). But water 'looks' great. What am I missing?
    13,500 gal AG, cartridge filter, 2 sp Waterway pump. TF-100 Test Kit (Love it !!) Repeating Pool School.....learn something new everyday !
    Sep 2009
    Greentown, IN
    914
    Re: yellow area under skimmer and return flow
    If you have CC over .5 or don't hold chlorine overnight you need to shock until you meet those two criteria in addition to clear water. Check out the pool shocking section of pool school.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Sep 2009
    Alabama
    22
    Thank you, I thought so but was concerned that CC is way higher than FC. Will shocking increase CC as well as FC?
    Sep 2009
    Greentown, IN
    914
    No, it should not make the CC go up, but down throughout the shocking process.
    You get CC when there is something in the pool causing the chlorine to break down. The goal of shocking is to remove/kill whatever is eating up your chlorine so you no longer have CC or the chlorine odor they cause.
    Test kits compared
    Purchase test kits
    Sep 2009
    Alabama
    22
    Thank you so much for the help, and the explanation, makes sense. I didn't want to believe something was still there, the water is so clear but the numbers don't lie, do they Adding bleach now.
    Butterfly's Avatar
    South Carolina
    10,045
    What are the ingredients in yellow clear?
    You're done SLAMing when:
    30,432
    I think sodium bromide which is a huge consumer of chlorine and will account for the cc's.
    If something from the pool store says "yellow...(anything)" DO NOT BUY IT
