Results 1 to 11 of 11
Thread: Rapak Model PR267A-EN-C FFL Error Code
    When I started up my Raypak PR267 low nox heater this week the heater was firing but cutting out frequently. I had this problem a couple of years ago and cleaned the pilot and rewired the frayed ground wire between the pilot and the valve. The unit has run well up to now. Today I proceeded to clean and refresh the ground connection since the green wire was cooked black. After reassembly, the unit would not even spark. The fault code FFL comes up and then nothing. I tried taking out the pilot and making sure the pilot was not blocked. I reseated all the wires on the gas valve to make sure they were making good contact but I stuck with the FFL fault upon reseting the power. Anybody have a guess what I did to cause the FFL error.
    24ft Doughboy Signature Series 52" Deep
    14,600 Gallons
    Polaris 65 Vacuum
    Used Pristine Blue for about a month and making the switch to the BBB method was the best thing I ever did!!!
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Rapak Model PR267A-EN-C FFL Error Code
    Instead of responding by asking you questions and going back and forth...
    Here.
    Factory Warranty Station for:
    Thanks for the information. I have a control board on order and will post whether the new controller resolves the FFL fault. What puzzles me is how the controller senses whether there is a flame. The electronic low-nox system has no thermocouple. It just has a spark wire and ground wire going out to the pilot.
    14,600 Gallons
    Polaris 65 Vacuum
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    In ignitor has a dual purpose and can tell if there is a pilot or not. The page Pool Clown is showing you says to the right of the image "Indicates flames signal at PILOT before SPARK initiated and pilot established." You should also investigate why you have "cooked" wires. Under normal conditions wires should not get "cooked."
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    The ground wire attaching to the pilot assembly was black for about 1/4" but not melted. I'm thinking this happened on a windy day and some flame spilled back. The heater is near the side of a building but the installation complies with the installation code and passed inspection. I could add a stack to lessen the chance of flame damage.
    I am attaching a file that explains flame rectification which answers my question on how the controller senses whether a flame is present.
    Attached Files Attached Files
    14,600 Gallons
    Polaris 65 Vacuum
    I just dealt with the same thing, probably the equivelant error code to my 406A.
    http://www.troublefreepool.com/raypa...re-t42644.html
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    GKruske, My issue is different in that I get a FFL fault right after the temperature is displayed during power on. My system is detecting a flame before it gets to the CFH or SRK stages and is shutting down. I replaced the pilot assembly already and confirmed my grounding. Poolclown above sent a maintenance page that lead me to believe the problem is my controller board. My systems still shows an FFL fault even with the ignition wire removed at the control board. I will post again when I try the new board tomorrow. By the way there is no thermocouple involved. The controller senses the flame through a mico current that is rectified by the flame when present (see attachment above).
    14,600 Gallons
    Polaris 65 Vacuum
    Interesting. I certainly hope a new PC board solves the problem....been there, done that. I know how expensive those things are!
    Kansas City, MO
    1.5 HP single speed
    The new controller board resolved the FFL error code. I had some confusion with the instructions which stated that for a low nox unit a circuit board tab should be left in place. The instructions stated "for Low NOx Only....DO NOT break tab". I observed that my original board had the tab removed. I tried the board with the tab in place, the unit fired but then I got a message that read "Tab" and the unit shut off. I cut the trace on the back of the tab and the unit works perfectly now. The job took less than 30 minutes included taking a photo of the board and sketching all the connectors and wire color positions on a note pad.
    Thanks for all the help, looks like the pool will be cooking for Memorial Day. Have a safe holiday!
    14,600 Gallons
    Polaris 65 Vacuum
    To whom it may concern. My system too gave the FLL right after the temps. I didn't see the pilot still going until I looked really close. It's very easy to miss that the pilot is still running since it was a smaller version of the actual pilot when all was working correctly. Replacing gas valve now. I disconnected all wiresw from the valave and still saw the pilot running so it seems pretty positive it is the valve.
    Well thanks to this web-site I saved a bunch of time. It turns out the gas pilot was stuck on, I changed the valve and all is good. The test where you remove the ignition wire and listen for a spark was very helpful. I heard the spark when the wire was disconnected which told me it had to be the system was detecting a pilot. Again anyone doing this be careful to look closely, the pilot was very small but present!
    Are these valves repairable or are they throw away. I'll take a quick look, my guess is corrosion. I'll let you know what I find.
