Results 1 to 7 of 7
Thread: Debate!! Fact or Myth
    May 2012
    Small midwest town In illinois
    55
    If you have a solar cover on your pool, the sun will not eat as much chlorine as if your pool was uncovered?
    Having this debate, and I know you have the answer!
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    Nov 2010
    Calera, Al
    271
    Re: Debate!! Fact or Myth
    Correct!
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Solar cover saves significantly on chlorine.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    mas985's Avatar
    Pleasanton, CA
    11,737
    Depends on the cover. Clear covers will not prevent as much UV extinction loss as a colored or opaque cover.
    Mark
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Quote Originally Posted by mas985
    Yes....but even a clear cover will prevent loss compared to no cover.
    Jun 2008
    Marana, AZ
    347
    Big savings on chlorine with a solar cover!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    22,550
    I use a clear cover and can't tell any difference in FC loss whether it's on or off. Absolutely no difference. It does make a big difference in heat retention.
