Results 1 to 15 of 15
Thread: D.E. filter vs. Sand or cartridge filters
    Apr 2010
    West Hollywood, CA
    32
    I have a 15'x25' oval pool and it's about 30 years old. It's about time to replace. I am looking at same size pools and they come with filters and pumps. All seem to offer sand filters but I have always had D.E. filters.
    Which is better? What are the differences? Thanks for any help on the subject!
    [center:3jp7r7gm]15'x25'x4' Oval Muskin AGP, blue vinyl liner, sunk 2 feet in ground with redwood decking. Approx 10k gallons. Hayward Perflex filter D.E. and Hayward 1.5 hp pump. One return line. Wedding cake stairs. (whew, hopefully that describes the pool!)[/center:3jp7r7gm]
    Feb 2012
    Phoenix, AZ
    728
    Re: D.E. filter vs. Sand or cartridge filters
    A sand filter will filter down to 40 microns, and require back-washing somewhat regularly
    A DE filter will filter down to 5 microns, and require back-washing (less often than sand)
    A cartridge filter will filter down to 10 microns and cartridges are cleaned manually (no backwashing)
    Apr 2010
    West Hollywood, CA
    32
    Quote Originally Posted by blakej
    Sounds like a cartridge does the best filtering and the D.E. next best or am I reading this wrong?
    Feb 2012
    Phoenix, AZ
    728
    DE filters out the most 'junk.' (based on the lowest micron filtering ability)
    Cartridge still do a great job, but not quite as well as DE. They are, however, easiest to clean in my opinion. Some people might disagree, but I would rather hose off a cartridge than backwash and add more DE media or sand.
    Apr 2010
    West Hollywood, CA
    32
    LOL, I realize I read it wrong -- of course the D.E. filters out the most junk! So I think I'd like to stay away from sand filters. Go with another D.E. or try a cartridge! Yup, I'd rather just hose something off than do all that backwashing and messing around with adding more D.E.
    Thanks for the input!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you live in an area where water is expensive or use may be restricted during dry seasons, you may want to more strongly consider cartridge filters.
    Ike
    Mar 2010
    Spring, TX
    1,082
    I switched from a DE filter to a cartridge. Now my cartridge is a step up from my DE filter so I am getting more filtration. I have not noticed a difference in clarity since I have switched.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by mynewpool
    A DE filter will filter our smaller particles than a cartridge filter can..BUT the difference is not usually noticeable to the human eye.
    Mar 2010
    Spring, TX
    1,082
    Yea I know that, but I also went up in size with my cartridge filter so I assume I am getting better filtration, but I could be wrong which would not suprise me haha.
    Apr 2010
    West Hollywood, CA
    32
    Sounds like cartridge is the way to go. I won't miss having to backwash and replace the D.E. that's for sure. They sound a lot easier to clean!
    Casey's Avatar
    SW PA
    10,438
    I loved my DE filter and would buy another one in a heart beat over the sand or the cartidge filters. I've never owned a sand or cartridge but I love the DE filter enough to not want anything else. I don't mind the extra work of pouring in DE to reload. Pool Care is dang near non existant here at TFP with the BBB or SWG.
    mas985's Avatar
    Pleasanton, CA
    11,737
    One thing that hasn't been mentioned is that since a cartridge filter does not have a backwash valve, it is also the most energy efficient (i.e. lowest head loss) of all three filters. So the energy factor (gallons/watt-hr) will be higher on a cartridge pool.
    Mark
    May 2009
    Dallas, TX
    782
    I made peace with my DE filter after switching to cellulose. In the process, I discovered an easy way to clean it. Barb adapter in the drain to hook up a drain hose, then spray off the grids directly within the housing. No disassembly required. Superior filtering + easy maintenance, what's not to love?
    Still if I was buying new I would probably choose cart...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Apr 2010
    West Hollywood, CA
    32
    Quote Originally Posted by mas985
    Considering how high our electric is in Los Angeles, I could use the more energy efficient cartridge! I do love the D.E. filter, but again, never had anything else!
    Jul 2014
    Palm Coast, FL
    1
    Quote Originally Posted by catchyoulater View Post
    I've owned a Pentair cartridge filter for 7 years. You need to remove the filter once a month and spray it with your garden hose. Once a year you will need to buy a new filter. Depending on size mine cost me between $75-$100 each year !
