Thread: What am I missing from my small intex pool with SWG?
    May 2012
    SoCal
    3
    I've fianally finished setting up my 12 x 30 metal frame intex with about 1750 gallons of water 2 days ago. I added about 35 lbs of Morton's pool salt and allowed my filter pump to run 24 hrs before turning on my SWG. I set my SWG it to run for 1 hour last night since my pool is pretty small.
    Today, after reading and learning how to maintenance my pool, I found out that I would also need to add CYA to the water. How much of the cyanuric acid do I need to add to my 1800 gallon pool? If I take a sample of my water to the pool store, how much water should I bring, a gallon?
    This is my first pool and it's for my 5 yrs old so I want to make sure that the water is safe for her to swim in.
    Thanks for your response.
    AGP Intex 12' x 30'' Metal Frame Pool
    Intex 637R/56637E 1000/gph Filter Pump
    Intex 54601EG Krystal Clear Saltwater System
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    Re: What am I missing from my small intex pool with SWG?
    Hi, welcome to TFP! You only need about a pint of water to take for testing, however if you purchase your own test kit you can do all your testing at home. TF test kits sells the TF 50 which is ideal for small pools like yours and would probably last a couple of pool seasons.
    Using the pool calculator with your pool statistics you should add 17 ounces by weight of stabilizer or conditioner to raise the CYA to 70 ppm.
    Love TFP? Become a
    TFP Supporter!
    May 2012
    SoCal
    3
    Thank you Mod Squad for the great info. I'll definitely look at the TF test kits
