Thread: Just want to verify my numbers
    Apr 2012
    High Point, NC
    31
    My pool has been pretty stable and very clear since I started testing regularly and using the BBB method this spring. Thanks to you guys for all the great information provided.
    With that said, I just had 4 days of heavy rain + we had a leak with our heater that I had to fix, so my pool water turned over alot more than normal. The good news is that this almost solved my high TA "problem" (not so much a problem as much as me just wanting it lower per the guidelines). Still, I want to run these numbers by you all and make sure they are all good then I will quit worrying so much and just enjoy my pool.
    Current numbers
    FC - 4.0
    CC - 0.0
    pH - 7.5
    TA - 95 (turned on the tenth drop, but it was so close on the 9th that I am splitting the two)
    CYA - 35
    CH - 80 (vinyl AG pool, don't worry too much about this one)
    Am I correct in thinking that these are solid numbers and that I don't need to worry much about them? I think the CYA number is a little low (I lose about 2 - 3 ppm of FC per day with about 6 hours of full sun) but we have a week long beach trip planned early June and I want to leave some room to use 3 or 4 trichlor pucks to keep my FC up for the week. After that, I should have CYA between 40 and 50. Sound good?
    13,500 gallon AGP. Sand Filter. Swimmax Electric Heater
    Re: Just want to verify my numbers
