Thread: brown water overnight
    Jun 2011
    central Illinois
    10
    I hope this is the right spot for this question. I have read and read and have received great knowledge from this forum. So here is my problem. I had things headed in the right direction on the pool 2 weeks ago. Then the pump had bearings go out so I was not pumping water for 4 days. My FC got low again but when the pump got back I was able to get it back up. The water was gray but starting to clear when I needed more water. Started adding from the hose, city water, and the next day I have brown water. Is this iron in my water and with my FC at shock level it turned it brown? What should I do?
    From the tf100 test kit
    FC 11.0
    CC 5.0
    ph 7.2
    TA 90
    CYA 25
    10,000 gallons inground, fiberglass
    Thanks for the help.
    22,550
    Re: brown water overnight
    It sure sounds like iron. Get a recent water report from the local water dept and see if it has iron. Iron will sometimes percipitate at high FC levels and you may get lucky and it'll filter out.
    Jul 2011
    St. Paul, MN
    244
    I had this problem last year after I had my liner replaced. My DE filter was able to catch the oxidized iron. It took about 6-8 filter cleanings to remove it all. See the picture below of my filter full of iron particles.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Jun 2011
    central Illinois
    10
    WOW!! Will I have this problem every time I add water or will it not be as bad because I won't be at shock level?
    Jul 2011
    St. Paul, MN
    244
    For me, it only happened that one time. It was when I had just refilled my pool because I got a new liner. It may happen other times, but I don't notice it because the amount of fill water added is much less and therefore there isn't enough oxidized iron to be noticeable. I've also been using sequestrant regularly (8 oz. of Pro Team Metal Magic per week).
    I'm on municipal water. I had my fill water tested at the pool store, and they didn't find any iron - for whatever that's worth.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I have loads of iron in my water. I find after the initial fill and shock it gets filtered out. I sometimes speed the process up by putting DE in my sand filter. I get brown iron stains around where my auto-fill valve is piped into the pool shell. I'm considering a "Birm" filter or some kind of pre-treatment tank (that feeds the autofill valve and is where I add chlorine and flocculant before it goes into the pool and drain off the precipitate from the bottom of the barrel).
    I did a no-drain acid wash this spring that worked well in getting rid of the stains.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
