Thread: Boric Acid, Powder or Granular?
    Round Rock, TX
    529
    Does it matter which is used in the pool? I would think that maybe powder would dissolve quicker/easier, but is also more costly.
    What is recommended?
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Re: Boric Acid, Powder or Granular?
    Both kinds dissolve very quickly. At least one person has had a rough time using the powder, though others have not had a problem with it.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I used granular and it dissolved very easily. I chose it because I thought powdered might clump.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Round Rock, TX
    529
    Thanks my searching mojo isn't as good as yours. I figured someone here had tried both, but couldn't find it.
    dave
