Thread: Cartridge Filter No Pressure on Gauge
    I have a new pool with Pentair C&C Plus 320. Pump is VS3050 (1200rpm). Gauge on Filter reads 0 pressure. System is purged and water is flowing. Shouldn't there "some" pressure? Lines are all 2". 19,800 gallon pool.
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    22,403
    Re: Cartridge Filter No Pressure on Gauge
    Not necessarily. Running at only 1200 rpm with a filter that large and all 2" lines your gauge may not register that low a pressure. Crank the pump up to about 3000 and it should read something. You can also get a 0-30 psi gauge and it will probably read a couple of psi.
    Whew... I feel better.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    I have a setup similar to yours (Intellipro VS rather than Intelliflo); at 1500 rpm I also get a pressure reading of 0. Actually, if I stare at the pressure gauge carefully enough, it seems like it has a "stop" at 2 or 3 psi. So, I guess I can't really measure below that with my gauge anyway.
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
