Thread: Skimmer and Main drain questions
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    Good afternoon everyone,
    After pulling my hair out this morning, here I am. I am starting up my equipment.
    I have backwashed the filter, rinsed, and set to filter. I primed the pump. Finally, water is coming from the returns nicely with the skimmers on and the main drain off.
    My issue: The skimmers dont seem to be suctioning at all. How is that possible since the returns are flowing, and how do I fix it? Also, I have 2 separate switches for the main drain and the skimmer. Should both be on at the same time or just one at a time? when I turn on the main drain the filter loses pressure.
    Im really afraid of screwing my system up, and very tempted to just call a pool guy even though I cant afford it!!
    Please help.... thanks in advance.
    ps - still waiting for the test kit.
    34K gallon, Hayward S240 sand filter, in ground, gunite... not sure of pump size and flow rate
    30,426
    Re: Skimmer and Main drain questions
    If you ordered it from TFTestkits, please PM me your name and I'll get you an answer.
    Post a pic of your valves and controls (make it complete) and someone will walk you right through it.
    Whaqt is the water level in the skimmers...it might be too high.
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    The water is about half way up... when I feel down where the water drains in the skimmer I dont feel any suction. I did the tennisball test and nothing. I tried turning the valve off and on and it sounds like something rattling. I dont know if that's normal.
    Im not worried about the test kit. I was just mentioning that Im still waiting (I went with the slower shipping), but thank you.
    I will try to post pics.
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    ok, Update: there is something that looks like a return on the side of the pool that needs to remain plugged. I had removed it thinking it was a return. I put it back in and the skimmers are working beautifully.
    Crisis averted.
    Yeah, that's a vacuum port, used for certain kinds of automated cleaner things IIRC.
    6000gal IG gunite // Hayward cartridge filter // rooftop solar heater // 32ppm borates
    Only two chemicals go in my pool! - bleach and muriatic acid!
