Thread: Vinyl liner pool CA and TA levels
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    I have a SW pool 56000 gal (no typo) My FC 3, CC 0, PH 7.1, Calcium 90, 240 Alkalinity, CYA 0. salt at 3300ppm, Pool is crystal clear no problems. Trying to lower TA and maintain proper PH TA was at 300 three days ago, is Calcium ok or do I need to raise to 200 and I will be adding stabilizer to get 70/80ppm. Do I need to do anything else?
    Had a leak, replaced liner and new water.
    Thanks
    Rich
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
    22,552
    Re: Vinyl liner pool CA and TA levels
    Don't worry about the calcium. Looks like you've got everything else covered. Aerate to raise pH and add acid to bring it and TA down, check; Add enough CYA to get to about 70 or so, check.
    Feb 2012
    Phoenix, AZ
    728
    According to the recommended levels in Pool School, your CH can be 50-300...so you are fine at 90.
    Continue to lower TA and your pH will become more stable.
    Getting CYA up to 70-80 is perfect since your pool is salt water
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Cool, thats what I thought but wanted advice.
    Thanks
    Saint Charles, IL
