Results 1 to 7 of 7
Thread: Too much salt...
    Mar 2010
    Huntington, WV
    150
    Too much salt...
    This is my first year with a SWG. I added a little too much salt, my numbers are 3700 and when I turn on my SWG after it has circulated for about 24 hours, it is giving me a HIGH SALT reading.
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    30,419
    Re: Too much salt...
    If it is producing chlorine you can ignore it. If not, you will have to drain and refill a portion of your pool water.
    Mar 2010
    Huntington, WV
    150
    Well, since it reads and error, flashes and beeps, the "working" green light is not on, so I doubt it is making chlorine. Will it not go down on its own?
    24' AGP
    No it won't but that is the great thing about salt is it's consistency. If your pool is open and you get a lot of rain that could dilute your water and lower the salt. To lower it, you'll need to drain part of it and refill. Drain 3" and add 3" of water and wait a day and see what your salt reading is. Keep a record of this so you'll know how much water affects your salt level. For example, if the salt reading drops from 3700 to 3500 you'll know that for every 3" you drain & refill will bring your salt level down 200.
    POOL SPECS - 18' round AG pool Doughboy pool with 5'8" deep-end, Aqua Trol Salt Water Generator, 1HP Doughboy pump, Doughboy sand filter, Solar Dome cover and a 40'x4' solar heater. Located in Oregon with swimming season from end of May through September. I pull the pump & SWG during winter months. Solar Dome minimizes FC loss & keeps heat in & debris out. Btw - Solar Dome lasted about 6 years before plastic started shredding.
    Mar 2010
    Huntington, WV
    150
    got it. I just backwashed for a few minutes, it was dirty anyways. I will add some water this eve and see what the next test results reveal. Thanks.
    24' AGP
    Mar 2010
    Huntington, WV
    150
    replaced water, all is good on the salt levels. But will the CYA levels be lower now? I have not checked yet, but thought by replacing the water, it will decrease the CYA in the pool.
    24' AGP
    Yes, replacing water will have lowered your CYA level. However, it doesn't sound like you replaced all that much water, so it is likely that CYA wasn't reduced by very much.
