Thread: Question about breakers, subpanel, gfci
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    408
    Hi-
    I'm planning on adding a Suntouch to my pool to replace the intermatics I have and automate the valve on my solar panels. The main circuit feeding my pools subpanel is 40amp. This is shared by my furnace, which is gas and therefore probably uses a small fraction of that 40amp. There's 240v going out to my pool panel (iirc the main and booster pump are hooked up for 240).
    My current subpanel has three breakers; 1 for main pump (1hp), 1 for booster pump (3/4hp), 1 for 120v lights (gfci).
    QUESTION.... When I install the Suntouch, I understand that I need to still have gfci. The recommendation in the manual is to go from the relays to a subpanel then to the equipment. To keep it simple I would like to have 1 main GFCI breaker. Seems to me that I can one of two things; install a GFCI in my main/house panel and nowhere else in the system, OR, install a GFCI in the subpanel downstream from the Suntouch. The first option is cheaper. Is one better than the other? With the 2nd option I won't be able to have just one gfci breaker, I would have to get one for each pump and the pool light. ?
    A 3rd option, mentioned in this link (wiring-question-upgrading-to-a-suntouch-controller-t42815.html?hilit=suntouch) would be to have main power come into subpanel (1 main gfci breaker) THEN power to the Suntouch and the pumps from there.
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    Dec 2009
    Central Massachusetts
    2,690
    Re: Question about breakers, subpanel, gfci
    You want to put a GFCI breaker on each piece of equipment you need to protect. Putting one in the main to protect the whole sub panel is not the correct way to do it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    408
    Thanks bk406. When you say "not correct" do you mean as a best practice or not code? Also, whats the disadvantage? The voltage from the different devices causing false gfi trips?
    Dec 2009
    2,690
    Well, a little of both, really. Code says the pool light and the pump needs to be on a GFI/GFCI protected circuit. That would mean, if you read the letter of the code, protecting the entire panel wouldnt be correct. Even if it somehow passed inspection, it's not best practice either. If the pool light encountered a situation were it needed to trip the GFCI breaker, there could be an issue since the GFCI breaker would be in the main on the entire 240 volt feed. Again, its just not good practice to do it that way. Buy the breakers you need and do it the right way.
