Results 1 to 11 of 11
Thread: Accent Tiles. Like 'em or Leave 'em?
    Aug 2010
    Charleston, South Carolina
    77
    My pool plans call for accent tiles of a contrasting color on our steps/benches/tanning ledge. What is everyone's opinion on them? I'd love to see some photos!! While I think it would be nice to delineate the edges, I kind of like the uniform look of not having them. What's everyone else think?
    Inground, Shotcrete pool,
    CL KrystalKrete finish,
    19,000 gallons,
    Pentair equipment.
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: Accent Tiles. Like 'em or Leave 'em?
    For those of us with less than perfect eyesight, and for those times when the sun or shadows conspire to hide those step edges, the contrasting tile insets are really nice. It does not take too many, but really does make a difference. They look nice, and increase safety at the same time. I do not have any pictures. My pool does not have them, but I wish it did. My parent's pool has them.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Apr 2012
    Texas
    32
    We have accent tiles. The pebble plaster color and the tile blend really nicely together in shades of gray/blue/tan so they don't stand out a whole lot but just enough to dilineate the height changes. I would definitely recommend doing them in your pool.
    Jana - Central Texas
    Pool Stats: Approx. 20,000 gallon freeform pool completed 5/3/2012. Pentair Triton II Sand Filter, 2 - Heyward Super II Pumps, In-line chlorinator, 3 water sheers on 36' raised beam, CrystalStones Mini Pebble Finish in Caribbean Blue, Leuder Limestone coping and raised beam, 1300 sq. ft. stained and stamped concrete decking.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    They add to the looks and also provide an extra safety factor to our white plaster pool. Ours are simple brown squares on both our stairs and hot tub. I like them.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    My wife wanted them bad. The pb tried to talk her out of them. She ended up calling pebbletec who made the ones we were looking at and if you can believe this, they talked her out of them too!!! Even though the installer was a certified pt installer no one wanted to do them or sell them for that matter...we ended up leaving them out. But they are pretty.
    30,000(ish) gallons
    SPARCO - High rate sand filter
    In-Ground, Tiled sides
    Unknown for everything else.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I put a dozen 8x8 tiles set in a pattern on my tanning ledge and seating bench. My pebbletech is pearl white and the tiles are a light blue, not a lot of contrast, just enough. I didn't bother with my steps. The single step down onto the tanning ledge is quite visible as its only down a few inches and there is just one other step and it's cut into the tanning ledge surface.
    I don't think I would like small tiles but these set on a diagonal 18 inches apart looks good. I set the tiles my self after my shotcrete was finished before the pebbletech crew showed up.
    chiefwej
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    What did you paint/stain your deck with?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by bobodaclown
    It's an acrylic surface. Similar to Kooldeck but not porous, stain resistant and very easy to recoat.
    First they put down a texture.
    It looks like this.
    Then the final color coat.
    chiefwej
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by chiefwej
    I like your choice of waterline tile & pebbletec color. Very classy.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Pebbletec is pearl white and the waterline tile was selected to match the calcium buildup that shows up here so quickly. Fortunately once I learned how to keep my water in perfect balance here at TFP that's not as much of an issue.
    chiefwej
    May 2009
    Dallas, TX
    785
    Well, I understand the practical decision, but I like the white on white. Very clean looking.
