Thread: Submersible Pump for Watering Lawn
    Sep 2010
    Indianapolis, IN
    23
    Anyone here use a submersible pump in their pool for watering their lawn? Given that I occasionally drain some water out of my pool a few times each year I was wondering about watering the lawn and vegetation with it instead of just draining all in one spot. I have a sump pump that I use as my homemade aerator but when I tried fitting to a garden hose it only produced enough pressure to drive the sprinkler a few feet high. So I'm assuming there is a different kind of pump needed.
    Not a big deal but would sure be nice to use pool water in these cases instead of paying a higher water bill to water the lawn AND refill the pool.
    13K Gal, In-Ground, Fiberglass, Cartridge filter (Jandy CL340 127 flowrate), 1 HP Pump (Jandy PlusHP)
    30,426
    Re: Submersible Pump for Watering Lawn
    the submersible pump will not produce enough pressure.
    Sep 2010
    Indianapolis, IN
    23
    Thanks. Actually doesn't have to be submersible. What kind of pump would be recommended for this?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    I don't use a sprinkler, I just lay the hose on the lawn and let it flood and move it every so often.
    I've also stopped using the submersible. For whatever reason, there's a hose fitting on my return line, so I just tap onto that to drain and water at the same time.
    Jul 2011
    Webster,Wi
    62
    I tried the submersible pump last year when I was trying to make a homemade solar unit work but lo and behold the pump broke internally and I had an Exxon Valdeze(sp) in my pool. The pump's motor used oil internally to lube the parts and when it broke the oil leaked out. I then tried a lawn pump that I had to use pvc pipe from the pump to the pool and it works great and no worries because the pump sits on the ground and not in the water.
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
