Is GFIC required on a 220v pump?
You just haven't looked hard enough !
Last summer, When I replaced my pump, I also hangout on a home improvement forum. Yes the pro electricians said it SHOULD be on a GFCI circuit (even for a 240V ). Warning - sticker shock. The panel that my pump gets power from uses GE breakers (relatively inexpensive for the GFCI 220V) - and I paid around $100 - $120 buying over the web for the correct GFCI breaker .
Some of the "is it required" is something you should check with your local building codes inspector.
