Results 1 to 7 of 7
Thread: Cutting solar blanket into sections
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    I have a terrible time getting the solar cover on and off my 30 ft. round pool. I've read that some people cut them into sections to make it easier to put on, off. Since I just purchased a new cover I thought I'd cut the old one into 4 sections and see how it goes before cutting up the new one. How do you get the sections far enough towards the center of the pool? I have 4 sections all bunched up around the edge of the pool. Any suggestions welcome! At this moment, I don't think I'll be cutting the new cover.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Sep 2009
    Greentown, IN
    914
    Re: Cutting solar blanket into sections
    I would love to hear any suggestions as well.
    Hubby and I cut our cover in half thinking it would be easier for me to handle when he wasn't here to help me and the kids wanted to swim. Unfortunately, we found it to be just as difficult for me, if not more so, in two pieces than in one. We ended up zip-tying it back together and attaching it to a reel so I can maneuver it on my own, although not easily.
    We have a round AGB with decking all the way around... a small sitting area to one side, but no place to store the cover when not it use. Hubby made some hooks on the outside of the pool railing to hold the reel and cover during swimming, but if I manage to get the reel and cover there I can't get it back on the pool when swim time is over... too heavy for me to lift back over the railing. I tend to just rest the reel and cover on the top of the rail when I know I will be the one putting it back on by myself, but there has to be a better way. I almost wish we had added the expense to extend the other side of the deck far enough to hold the reel and cover when it wasn't on the pool, but hindsight is 20/20. We didn't expect the reel and cover to be as heavy and cumbersome as it is, and here in Indiana, probably much like yourself, we have such cool evenings in the late spring and early fall, it's a necessary item.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jun 2011
    Long Beach, CA
    2,790
    You might try cutting it in 3 ten foot sections. This will give two "D" shapes and a semi straight piece for the center section. With this configuration you can pull the cover from the edges of the pool and there will not be any pie sections in the middle.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Take a look here http://www.ellerbach.com/Pool/Solarcover/, I'd seen links to this before but had to go looking for it. I'm thinking of doing it once we get our pool up.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2008
    Marana, AZ
    347
    I had ended up with a "sectioned" solar cover because when I needed to buy one for my 20' diameter pool last year the only stores that had them in that size were selling them for around $150. However, Lowe's had a 32' X 16' rectangular cover for a lot less, so I made my own. Turned out I needed 3 pieces to get the whole pool covered. The only way I can really get the pool covered in the middle is by being in the pool for most of the putting the solar cover on. The other thing I have done is use the pool pole with a brush head to scoot the sections around. The biggest problem I have is the wind; it blows the sections off a lot easier than a whole cover. And I use a lot of bleach jugs filled with water to keep the sections at least sort of where I want them once putting the cover on.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Thanks for all the suggestions. In the end, I decided not to cut it. As soon as the water warms up and the grandkids start swimming, I'll get them to pull it back on before they get out of the pool. I tried twice with the cut up sections and it was even more frustrating than dealing with one large piece.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    I have a free form pool and WISH when I built it I installed an automated cover....
    But I did cut my solar cover into 3 pieces - THEN I zip tied 1/2 PVC pipe with caps where I cut it- going across the pool. This makes it easier to take off and roll up and wash off in smaller pieces. Also wrote on each piece with a sharpie marker so I know what piece goes where... I tied some nylon rope to the sections so I can pull them from the deck. I never get any help with my covers, and they are not always easy, but it works better than one big cover and no way to get it out of the pool.
    B
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
