Thread: Suggestion for vendor area
    Round Rock, TX
    Can we get a sticky at the top of each vendor with a link to their website?
    Just makes it a simple click through shopping experience
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    We don't use stickies here in the traditional way because once I set an item as a sticky, it is also added to the stickies page. However, you'll notice that all the companies listed in the vendor area also have links on the home page, so if you like, you can just use those.
    The other option would be to make an announcement in each of those areas, which is like a sticky, but too many of those can make the site look cluttered.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
