Thread: Sequesterant question
    Nov 2007
    Rockland County, NY
    65
    Hi...Just treated my vinyl liner pool for iron stains with Jack's Magic products. Just over a week later the stains are returning. Locally, nobody sells Jack's products... I have more Purple Stuff on order but don't want it to get worse...can I use the sequesterant from Leslie's in a pinch while I wait for the Jack's? Thanks.
    27ft Above Ground Pool
    Sand filter
    22,553
    Re: Sequesterant question
    Yes, you can. I don't blame you for wanting to use something.
    Nov 2007
    Rockland County, NY
    65
    Thanks Bama
    I'm about ready to pull my hair out!
    Sand filter
    Dec 2009
    Central Massachusetts
    2,690
    Go to walmart and buy the HTH metal out. It's the same stuff for about $10 a bottle instead of $20. I used Jack's for awhile but found the HTH works the same.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Nov 2007
    Rockland County, NY
    65
    Thanks for the tip. Would you know if Jack's Sequest test kit will work with the HTH product? I imagine there should be no problem if it is the same stuff , right?
    Sand filter
