Thread: Wall foam
    Wall foam
    I'm in the process of putting in a new liner for our AG pool. I have wall foam which is in sections. What is the best way to join the sections? Is there a specific tape designed expressly for this? Further, is it recommended I buy a can of wall foam adhesive? As the sand is already coving the pool bottom, is it necessary to buy pool coving?
    22,551
    Re: Wall foam
    Gorilla tape will work or even duct tape will work. Both of those may leave a noticeable indentation in the liner. Shipping tape should work and it's thinner.
    3M spray adhesive or wall foam adhesive will work and something should definitely be used.
    Sep 2009
    Greentown, IN
    914
    Re: Wall foam
    I believe we had one, maybe two seams in ours and used duct tape. I wouldn't know it was even there now without going around the pool looking and feeling for it.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Re: Wall foam
    Thanks for your answers. I do appreciate that! I think the thinner the tape the better, if for no other reason than aesthetics, appearance. I'll let you know what I choose, and the end result.
