Results 1 to 8 of 8
Thread: Okay to go ahead with adding borates?
    Here are my test results from moments ago:
    FC: 2
    CC: 0
    pH: 6.8
    TA: 60
    CH: 120
    CYA: 60
    Salt: 3200
    Temp: 80
    Is this okay to go ahead with adding borates? I know the pH and TA are both lower than what the borates how-to sticky post recommends, but won't that just reduce the acid requirement?
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Okay to go ahead with adding borates?
    You never want your pH below 7.
    Best to use the recommended levels from the directions in Pool School.
    You're done SLAMing when:
    Quote Originally Posted by MeSue
    FC: 2
    CC: 0
    pH: 6.8
    TA: 60
    CH: 120
    CYA: 60
    Salt: 3200
    Temp: 80
    Your biggest issue at the moment is your low pH. It could possibly be even lower than 6.8 because i think that is the bottom of the test chart. So raise your pH using baking soda or borates. The amount needed can be found using the pool calculator. A VERY low pH can be very harmful to your pool equipment as it can cause corroding/rusting etc. to your filter, pump, and other metal parts in your pool.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Okay, added borax to get pH up. How long to wait before testing again?
    Sue
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You can test for ph 30 minutes after changing it.
    Thanks. Now I'm at ph 7.4 and TA 80. Borates 10-15. Think it's okay to go ahead with adding borates after my swim?
    Sue
    Mar 2012
    Lebanon,Tn
    47
    Yes go for it!!!!!
    21x42 olympic sports pool
    18000 gal
    Intelliflo vs pump
    Pentair ic40 SWG
    Suntouch control
    TR100 Pentair sand filter
    Letro ledgen II pool cleaner
    Vinyl liner
    TF Test Kit's TF100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yep, commence borating.
