Thread: leaks in 24 foot round pool
    Does anyone have experience with fix a leak? I have small pinhole leaks down at the transition part of the liner where the walls of the pool transition to the bottom of the pool, I get small pinholes in this part of the liner anyone know what causes these small leaks, I can patch them but the next year there's always more to find. I'm going to try fix a leak to see if it helps, i read that it is kinda of a last resort but the only other alternative is a new liner,
    24K gallons, IG, Kidney shaped, DE filter, 1.5HP pump, plaster/gunite, built in 1992.
    30,426
    Re: leaks in 24 foot round pool
    Welcome to the forum. . Any chance your vacuum or auto cleaner is snagging that place where the walls and the floor meets?
    no I had this problem before I got auto cleaner,
    I have found them on the flat part to but seems to be more on the transition part where wall meets the floor of pool
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    How old is the liner? If brittle and old it will eventually fail. I found this out the hard way with mine in the winter when it let go and froze. Destroyed the walls so a tottal replacement was needed. But the pool was 30 years old so it eventually would have needed it.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
