Results 1 to 7 of 7
Thread: filter system
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    filter system
    The AGP we are getting comes with a 1hp filter system is this sufficent for a 24x52 pool?
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Probably bigger than it needs to be, but if it's matched to the filter it will be fine.
    That is about the right basic size, however typically the standard packages include too large of a pump and too small of a filter. So, while that system is sure to work, you might be able to do better by purchasing a smaller pump and a larger filter separately.
    i think it all depends on the size and style of filter
    a 1hp pump will be fine
    just find out what kind of filter it is
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by all your parts
    It's a pentair pump and filter. I have noticed that a few people here have them. So they must be pretty decent????
    *~ Laura ~*
    TF-100 Test Kit
    Pentair makes good quality equipment but that doesn't tell you if it is well matched to your pool or not. Do you have a specific model number for the unit you are looking at? They make several different models that are all 1 HP.
    Mar 2008
    Evans, GA
    323
    I'll find out and get back to you on it.
    *~ Laura ~*
    TF-100 Test Kit
