Results 1 to 8 of 8
Thread: Will an undersized solar cover reel work?
    Jan 2011
    Northern Illinois
    116
    Recently I got a great deal on a Odyssey solar cover reel. However, when I got it home I realized it was for a max pool of 24' (not the 27' it was avertised as). Can I get it to wok as is? It has three 8' lengths of piping (the 27' is suppose to have three 10' sections) and the lenghts are suppose to slide into each other at least 12". Thanks in advance.
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    Feb 2012
    Phoenix, AZ
    728
    Re: Will an undersized solar cover reel work?
    I am a little confused..
    Do you have a 27' solar cover that you are trying to fit on a 24' reel?
    Or do you have a 24' reel AND cover that you are trying to use to cover a 27' pool?
    Jan 2011
    Northern Illinois
    116
    Sorry for the confusion. A 27' solar cover onto a 24' reel.
    Feb 2012
    Phoenix, AZ
    728
    Well, honestly I have never done this before..but these are my thoughts...
    You could probably fold over the sides a little bit before rolling up the cover, BUT I would guess that your solar cover will wear out quickly where the folds are. They are not the most durable ...but then again, I cant imagine this being any worse than folding up the cover for storage. I am eager to hear if anyone else has any thoughts/ideas.
    Jan 2011
    Northern Illinois
    116
    Thanks Blake. I only spent $30 for the reel so don't want to spend a ton more to modify it. I contacted Odyysey and they want $136 for an extension plus $25 for shipping so that is out of the question. The guy I purchased it from said I could return it to him for a refund but I'd rather keep it if I can make it work.
    Jul 2011
    St. Paul, MN
    244
    My solar cover doesn't track straight when I wind it up, so I end up with some folds in it. It does seem to wear the cover a little in those areas, but it doesn't ruin the cover. I would try to make the reel work since you got such a good deal on it.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by pmsmith2032
    What size tubing does it have? Maybe it's the kind of thing you could find at home depot?
    Jan 2011
    Northern Illinois
    116
    It's approximately 3" wide but has channels cut into it. Maybe PVC or something inside it?
