Thread: Adding Chemicals in new pool setup.
    May 2012
    Gulfport, MS
    59
    Sorry if this a "Beating a Dead Horse" question. I just want to make sure I am VERY clear on what to do.
    Adding bleach to new water--Pour straight in the pool in front of the return jet?
    Adding Stablizer--put in an old sock and hang in front of return jet
    Adding baking soda--dilute it and pour in front of return jet?
    Adding Muratic Acid--slowly pour into skimmer basket?
    Adding Borax--Dilute it and pour in front of return jet?
    30'x54" Round Vogue Simbio AG ~21,000 gallons
    Pentair Sand Dollar SD 60 w/ Pentair Dynamo 1.5 hp Pump
    Vinyl Uni-Bead 25mil Liner
    Perfect Bottom w/cove
    Taylor K-2005 & K-2006 Test Kit
    Re: Adding Chemicals in new pool setup.
    Muriatic acid is the one chemical you should never pour into the skimmer. We don't recommend pouring anything into the skimmer, even though the only one with an actual risk of damaging something is muriatic acid. Like chlorine, muriatic acid is poured slowly in front of a return jet while the pump is running.
    May 2012
    Gulfport, MS
    59
    Whew...and that's why I ask questions..Thx again.
    Butterfly's Avatar
    South Carolina
    10,045
    See the last paragraph of each chem article for recommended way to add chems :
    pool-school/recommended_pool_chemicals
    You're done SLAMing when:
