Results 1 to 7 of 7
Thread: Hooking up the pump
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Hooking up the pump
    I have a question on hooking up the pump. The pool company we are using doesn't do this part. Just how hard is it to hook up a 110 volt thingy? and how expensive can it be. One would think for 5k they would include this.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    There are a bunch of local rules to meet, and most pool builders don't do the electrical work. You'll need to find an electrician with pool experience to do it.
    Dec 2007
    Central New York
    504
    Re: Hooking up the pump
    Quote Originally Posted by lulupalooza
    If you don't know about electrical "thingys", get an electrician to hook the pump up to code.
    After all, you, your kids, your friends; will be using the pool.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Aug 2007
    Powhatan VA
    50
    The electrician that wired my pad charges $45/hr. I ran the feeds from the electric panel to the pad. The electrician did everything else, supplied all the outdoor boxes, etc, and dispensed valuable advice. I have a pump and 2 lights. The total bill was $350. Not bad for peace of mind.
    Don't try to do it yourself. It will likely fail inspection and cost more to correct. Just my .02.
    20x40 IG Vinyl
    33k Gallons
    Triton TR-100 Sand Filter
    Pentair WFDS-6
    Mar 2008
    Evans, GA
    323
    Thanks ya'll no way would we do it ourselves! Just was looking at a ball park figure. So this is on my list of to do things for today. I called a couple of electricians last week and they never called back.
    *~ Laura ~*
    TF-100 Test Kit
    Mar 2008
    Maryland
    56
    Is this a new pool build or are you simply reinstalling the motor that you so wisely stored indoors over the winter? If so and there is existing electric you could re hook it up yourself as long as ALL BREAKERS ARE OFF.
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by muss08
    This is a new build. I have gotten someone who is coming out and hooking everything to the existing outlet we have outside for 125.00
    *~ Laura ~*
    TF-100 Test Kit
