Thread: First Time Opening Pool by Myself
    The last 2 seasons my pool builder came and opened my pool for me. I feel like a dead beat not doing it myself, so I just want to make sure I have everything covered off.
    1. Remove Safety Cover. Clean off any debris, fold it up, and put it in the cover
    2. Close off all safety cover bolts
    3. Remove all return plugs and install eye balls.
    4. Put underwater lights back into place
    5. Hook UV unit back up
    6. Replace all drain plugs
    7. Check fittings to make sure they are all tight
    8. Add a bucket of water to prime the pump
    9. Turn on pump
    10. When air stops coming out of the filter valve and water start to shoot out, close the valve on top of the filter.
    Am I missing anything?
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    22,548
    Re: First Time Opening Pool by Myself
    I'd leave #5 out Be sure to check the skimmers for plugs. Other than that, looks like you've got it covered (or uncovered as it were)
    She's up and running.
    And I wish I didn't have #5, but I have it so I use it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Easto
    Unless you constantly have large swimming parties, it is probable cheaper to leave it off and only use it when you do. The UV will tend to require more chlorine (compared to being off) the rest of the time.
    Sep 2009
    Greentown, IN
    914
    Congrats on your first official start-up on your own! Yeah for you!
    I'm guessing you have the water balancing act done since you didn't ask about that.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
