Thread: Junk around my drains
    Mar 2008
    Central VA
    328
    OK I'm a bit embarrassed to ask this, but I figure someone has dealt with it before. I don't remember this being so bad in the past, but this year I have alot of junk (leaves, bugs, who knows what else) in both of my pool drains. The pool is a '06 install, so these are the safety drains with all the little holes around the outside of the plastic cover, and stuff seems to be jammed up into most of the holes.
    I've run my robot over it, tried to brush the stuff, etc., but it won't budge, even with my pump off.
    Any ideas on how to get the stuff out? Or am I going to have to send one of my kids down there to manually extract? (Come to think of it, that could be fun to watch)
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    22,553
    Re: Junk around my drains
    You could try a manual vacuum if you have one. Or just the vacuum hose taped to the pool pole.
    Mar 2008
    Central VA
    328
    Duhhh I haven't used the manual vac in so long I had forgotten about it. Thanks!
    Todd
    Sep 2009
    Greentown, IN
    914
    I had a little bit of debris stuck to mine this year too. The manual vac took a few extra passes, but got most of it. After shocking, any tiny bits that remained are now gone.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Once it's swimmable, you can always dive down with a small bottle brush and try cleaning it out. I didn't have much success, can't seem to hold my breath long enough.
