Thread: Oto turns orangish colored when testing. What?
    May 2009
    Mn
    198
    So I know my chlorine level was 18 on 5/12, then dropped to 13.5 on 5/13 (night time, removed solar cover), and was only .5 lower on 5/14 (morning). I assumed today it was still high...but for giggles, I used my oto test when checking ph (7.5), and the test sample turned momentarily orange with each drop. I've had high chlorine before, but it was just a dark yellow. Could the iron in my water be affecting my tests?
    My water is clear from the top but not across. (when the light is on at night it is milky and I can see all different sizes of stuff whiz zing by)
    I've had to add tap water so I know there is iron in the water. A trip to the pool store is in order for tomorrow to get the metal out stuff...gosh I hate paying for that stuff but what do I do?
    My reagents are less than 1 year old. My other numbers are from 5/10:
    TA 160
    Ch 320
    Cya 40.
    I'm sure the TA and ch are up thanks to 1000 gallons of tap water. Cya will also be down which would account for the quick drop in fc the other day.
    Thanks!
    Eta:clarification on overnight loss.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Oto turns orangish colored when testing. What?
    Look at this thread, it explains the orange color:
    http://www.troublefreepool.com/cholr...or-t28961.html
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
