Thread: Need some Balancing advice
    May 2012
    Danville, IN
    21
    Got my TF-100 test kit today and performed my first tests, should have sprung for the magnetic stirrer. Still getting the hang of this, so not sure how accurate. Here's where I am:
    FC - 8
    CC - 0.5
    TC - 8.5
    pH - 7.2
    TA - 210
    CYA - 70
    CH - 590
    Salt - 2900
    Water is looking pretty good and clear
    I'm questioning the CH because it's awful high. I did have to shock quite a bit after opening. That was before I found TFP so I used Cal-Hypo 73%, which might explain the high CH. Question is, what to do about it? Clearly pH and TA need some adjusting. What is the best method for tackling these values? Appreciate any guidance provided.
    25K gal IG Vinyl Ell shaped pool, Pentair SuperFlo 1.5HP single speed pump,
    Pentair SandDollar sand filter (Zeobrite), Pentai Intellichlor IC40 Chlorine Generator
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,099
    Re: Need some Balancing advice
    How much Cal-Hypo did you use by your best bet? Even adding 20 pounds, it would only raise your CH around 50ppm.
    Can you test the water that you used to fill the pool with?
    Either way your best bet is to use fresh water to lower the CH levels. High levels of CH can lead to scaling in your pool. As for lowering your TA the best bet is by using muriatic acid. With this high of a level you're in for a process, but it's going to pay off in the long run.
    pool-school/lowering%20total%20alkalinity
    May 2012
    Danville, IN
    21
    I ended up using 30 lbs of cal-hypo 73%. Looking at my CC it still needs some more shocking. I'll be using bleach this time. I'll have to point my returns up to see if they break the water surface to bring pH up. I know it creates ripples but not sure that's enough. I use well water with a filter to add fresh water. Would adding softened water help or create more issues?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Run your CH test on your fill water and give us the numbers, this will help us know what your dealing with
    22,553
    I wouldn't let the pH get very high before I lowered it each time, until you get the CH down a good bit.
