Results 1 to 7 of 7
Thread: CYA Testing
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,104
    CYA Testing
    All this season I've been running with very low CYA levels. We started out around 15, but then added 4 pounds of stabilizer into the pool....thus bringing the levels up around 35. After about 2 weeks I tested again and I was right in the area. Today I added another 2 pounds into a sock and placed the sock into the skimmer to dissolve the stabilizer. After a few hours of the water flowing over it....and me squeezing it several times all the CYA was in the pool. I tested again and came up with a level of 55 which with the dull sky's today is right in range.
    My question is this.....
    I know that CYA takes about a week to show up in the tests, yet I had a result show up with the numbers I'd expect right after I added the stabilizer. Is it that SOME CAN show up right away after adding?? I did the test about 5 times, each with a reading between 45 and 60 on the test tube?
    30,431
    Re: CYA Testing
    Good morning,
    That "week" is sort of an outer limit based on anecdotal evidence received on the forum. In my pool it tends to show up within 24 hours but many others have reported much longer periods.......so we adopted "up to a week" to cover all the possibilities.
    Jul 2011
    Eastern Ohio
    7,104
    Re: CYA Testing
    Thanks Dave! Had me worried there for a second. I'll retest early next week to see the true reading again. Either way I'm sure it's above the pool stores reading of zero!
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: CYA Testing
    Quote Originally Posted by Leebo
    And well below the other pool store's reading of 350.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Jul 2011
    Eastern Ohio
    7,104
    Re: CYA Testing
    I'd be more inclined to believe the 350 reading.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: CYA Testing
    I have never tried testing mine that soon after an addition, but will say at least in my pool it seems to show 50% or so after about 3 days, 80% at around 6 days, and 100% by 8 days.
    Ike
    hawkeye's Avatar
    davenport,iowa
    118
    Re: CYA Testing
    All this season I've been running with very low CYA levels. We started out around 15, but then added 4 pounds of stabilizer into the pool....thus bringing the levels up around 35. After about 2 weeks I tested again and I was right in the area. Today I added another 2 pounds into a sock and placed the sock iinto the skimmer to dissolve the stabilizer. After a few hours of the water flowing over it....and me squeezing it several times all the CYA was in the pool. I tested again and came up with a level of 55 which with the dull sky's today is right in range.
    Its really more along the lines of saving you money on reagents cause you use alot to test cya.
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
