Results 1 to 8 of 8
Thread: Pool store measurements really can be bad
    So you can read and read all you want, but until you experience it yourself it is a bit hard to believe. My local store actually carries all the tests except the powdered chlorine test. They even sell really large bottles of some of the reagents for a great price.
    They use drops to run the test, the values were so off I was worried for a bit
    FC 5 --- My test - 5 (great!)
    pH 8.3 -- My test 7.4 (had my wife double check)
    CH 90 -- My test 190
    CYA 100 -- My test 45 (had wife double check)
    They were recommending that I add 42 ounces of acid which would have sent my pH below 7
    So to all you skeptical new folks, believe it - your pool store test can literally be totally off.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool store measurements really can be bad
    I just went through this today also, took sample in to get iron level checked after rust/iron was spilled into the pool.
    They showed CYA at 10, should be 30, CH at 80 should be 160, and TA as over 110, shoulb be 60 - 70, this ignores the FC since it could have faded in the sample, the only thing we were close to agreeing on was the pH..
    May 2009
    Mn
    198
    Yea, I often argue with them about the ph. They tell me it is super high and I'm such a smart butt that I do the test from the same sample before I get there. They often times would have me bottoming out in the 6's if I believed them. They also get my cya different every time. It can be 100 one week and 30 the next. I suppose if I averaged their numbers it would be about right (I was at 40 when they gave me a reading of 10 and told me to add stabilizer)
    Sheesh! Oh well we give them plenty of business for pool toys. I really only care if there is iron in the water or not.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by MNPoolDreamer
    Just wondering why one would trust their Iron testing abilities......
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Quote Originally Posted by march2012
    Multiplication by 10 is hard..
    Gotta love having a good test kit to do these tests yourself.. The last person i'm going to trust is an untrained monkey at the pool store.
    1970's kidney shaped pool. 23,000 gallons with concrete bottom and fiberglass walls, both painted in 2012 with epoxy paint. Single speed "energy efficient" 1 hp hayward super pump and hayward S-200 sand filter. Main drain leaks, and is thus disconnected. 16 mil ultraclear solar cover. Located in Northern Indiana. TF-100 Test Kit
    Aug 2011
    Metro Atlanta, Georgia
    161
    Quote Originally Posted by Alias
    I believe an untrained monkey would be an improvement over what I have dealt with.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I personally don't trust their numbers, but don't own an iron test and had an incident last week with rust/iron shavings getting into the pool, so I took a sample to a local pool store yesterday, and will take one to a different local store in the next couple of days. If both show 0 iron I will assume it is not going to be a big issue, I just don't see investing in an iron kit for a single test run.
    Ike
    May 2012
    Lexington, SC
    127
    I just don't understand how pool stores can get away with giving out such wrong test numbers. I went back to our test results from our most local pool store from 2010 (when we first bought house with pool and knew nothing!), and each time my husband went in (1x a week on average), the CYA results would go from 30 to 60 to 100 to back down to 30. Of course the other numbers would vary too, but it's obvious they're screwing around with the numbers if CYA is changing that often and that drastically. Should I file complaints when I see this happening? Does it even matter? It's so apparent how they make their money. "You need stabalizer." Uh-huh, sure we do. I just feel like I should stand outside their store and give everyone who pulls up a card with this website on it so they can stop being fooled and taken advantage of by these stores. Sorry...still fresh with irritation with these people! We've spent so much money with them. I guess they love an ignorant customer.
    13,500 gallons
    Sand filter
    IG
    TF-100
