Results 1 to 17 of 17
Thread: Thanks TFP and quick question
    Jul 2011
    CT
    56
    I installed an AGP late august last year. Got a good deal being end of season and went for it. This past weekend I started building a deck around it. I had to uncover it and found a lovely dark green murky pool. With the deck framing I had to re-do some of the hard line plumbing I had done last year. Last night was lots of skimming to get rid of the leaves that managed to get under the cover. This morning (after lots of reading here on getting rid of algae) I shocked it and let the pump run full speed all day. When I got home after work it was no longer green (cloudy blue) and I could sort of see the bottom. Some more skimming and bumping the FC from 4 to 15 again I think it will be looking good tomorrow morning! I am running the pump of low speed over night hoping that the DE filter doesn't get clogged.
    The money I paid for the TFP support was worth it just in knowledge and not having to deal with the pool stores and whatever chemicals the would have me buy. So far I'm in for 5 jugs of 182oz 6%. Seems like a deal for a full algae shock.
    Thanks for the advice and sticky's here!
    I went to Ocean State Job Lot and bought 4 cases of 12.5% for $3/gal. Seemed like a good deal and I think it should last most of the summer. I might get some more if you think that might not be enough? What do you think?
    Another question I have is:
    How do you get rid of the toads/frogs hiding under the top rail? They are so loud!
    Rob
    Sharkline Matrix 15x30x54, Hayward 1hp 2 speed pump, Hayward EC-50 DE Filter, Rome/Solarium 105k Heat Pump, Aquabot Rover Jr - Deceased - looking to replace it
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Thanks TFP and quick question
    Store that bleach somewhere cool. It loses strength just sitting around, and it's one of those curves where the higher the concentration, the faster it degrades. Sorry to be the bearer of bad news.
    I have an inground, so I'm no help with the frogs.
    Be sure to brush the walls and floor while you're shocking. Algae can grow a skin that blocks the chlorine. Brushing it exposes the stuff you want to kill.
    38,521
    I am not 100% sure you following the Shocking Your Pool process ... sounds like you have the right idea, but might be missing a few of the details ... like testing often and staying above shock level until you pass the 3 tests.
    If you keep the FC levels up, I would think the toads/frogs should move along or die ... either way problem solved
    Jul 2011
    CT
    56
    I am following the best I can while still having a job! I am testing often and actually added bleach when I got home, then more after testing again 1/2 hr ago. I brushed the walls and floor this afternoon so hopefully that will help. I'll check it again in a couple hours and see how it's looking.
    38,521
    Just making sure ... sounds like you are making good progress
    Jul 2011
    CT
    56
    This morning the FC was still down but not as much as I thought it would be. Water looked good enough to swim in. Skimmed, brushed, tested and cleaned and recharged the DE filter. I think the worst is over
    And I caught a little guy taking some laps so he's been evicted too.
    Now I just need to adjust the PH and CYA and get the heater hooked up and the deck finished, lighting installed and hook up the rock speakers. Not enough hours in the day to do everything!
    Jul 2011
    CT
    56
    This morning the FC level was the same as last night! Water looks great, frogs are gone, bugs are gone and all is well. How would you measure shock levels w/o the TFP Test kit?
    Ipe is coming monday so I can finish the deck. I'll post pictures if anyone wants to see the progress?
    Apr 2012
    Puglia, Italy
    133
    These guys always want to see progress.
    400,000 Litre in ground infinity pool, with 40,000 litre holding tank (116 235.703 04 gallon). Vinyl liner.
    Two Astralpool Cantabric sand filters, 900mm diameter, each with 550kg of sand.
    Two ESI MP6 1.5kw 3 phase pumps.
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Sure thing... I would like some pictures of your deck build. Congrats on the progress!
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Quote Originally Posted by Robl
    You would need a FAS-DPD test kit to measure chlorine at shock levels. If you have just the DPD kit you can purchase the FAS chlorine test separately from TF test kits(see the link in my signature).
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    CT
    56
    I know... I have the kit and was wondering how anyone else measures it. I know of 3-4 people that have pools and I'd be surprised if they a decent test kit at all. Sort of being sarcastic on the generic pool store test kits.
    Richard320's Avatar
    Jan 2010
    19,067
    You don't. You guess. Or you take it to the pool store and they guess. And sell you something that may or may not help. But you've figured that out already, or you wouldn't be here.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    The way I managed last year with a temporary pool after finding this site, was with a HTH 6 way. Not the best and I did have to "shock" once, but mostly I controlled the water and didn't let it get out of hand. What I did when I had to was dilute the pool water and test it. I only did a 50% dilution which would take me up to 10 ppm CL. While shocking, when I dropped into that range I would use the Pool Calculator to take it back above the minimum shock level. I only had a minor outbreak of algae and got on it quick so didn't have a battle royal, otherwise I don't think I could have done it. It proved to me that it was something I could handle with a good test kit and we are in the process of installing a bigger more permanent pool. And I already have the TF-100 kit to use with it.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Mar 2012
    Wichita, KS
    81
    ...and we are in the process of installing a bigger more permanent pool. And I already have the TF-100 kit to use with it.
    Dan, this is precisely where we are now. We sit by our (cautiously) clean, blue pop up pool and dream about next Summer. My main thing is that I want to protect the liner better. Lots of work to be done, but the pool is a great reward.
    -Bill
    Jul 2011
    CT
    56
    I left Friday for a family visit to MD on Friday. I left the pool at 15 on friday afternoon. This evening it was down to 4.5 and the water looks great. I think I beat the algae! Rover Jr is cleaning up the bottom nicely and the decking was delivered today. Pool season is off to a great start!
    Jul 2011
    CT
    56
    Does a solar cover help prevent chlorine loss? Just wondering if that helps along with the CYA at the right level.
    Solar covers vary in how much UV they transmit and thus in how much they affect chlorine lost to sunlight. Most of them are at least somewhat UV opaque and make chlorine last longer, but there are some that are UV transparent and have no effect on chlorine consumption.
