Thread: Should i add liquid chlorine while i wait for my test kit?
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    I ordered a TF100 yesterday.
    I just opened my pool and it is crystal clear and about 63 degrees. We just had 3 inches of rain and i still need to add another 6 inches of water (municipal water) to get to the correct level.
    I used the test strips i had left over and they showed everything to be more in less in range or slightly low except for the chlorine which was very low.
    Would it make sense to add a gallon or two or some other amount just to keep it clean a couple more days??
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Re: Should i add liquid chlorine while i wait for my test ki
    Yes. You don't want to let algae get a toehold.
    38,262
    Certainly would not hurt anything to keep some chlorine in it to prevent it from turning green ... although ideally you should have the pump running when you are adding chemicals.
    Nov 2011
    Albany, NY
    495
    Thank you ... any idea how long it takes them to get the test kit shipped out? ... it looked like it came from NC and has to go to NY so i should see it in a couple of days.
    Haywood Sand Filter
    Vinyl Liner
    38,262
    Dave is quick with his shipping ... hopefully by the weekend.
