Results 1 to 10 of 10
Thread: Pool Store testing terms?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    After last week's iron/rust getting dumped into the pool incident that was part of my remodeling / roof replacement project I took a sample of the pool water into a local pool store today for their "free" testing to get the iron levels (for what that is worth) since I don't have a test for metals since they are not usually an issue.
    Of course their numbers and advice came back questionable, did show 0 for iron and copper though
    Which brings me down to the question, one of their sections is listed as " Alkalinity w/ stabilizer correction their test showed 107ppm, my TF-100 TA test shows 70 ppm, does anyone know what this "correction" is? I am sure it is wrong whatever it is as their CYA reading was 10 ppm, mine was 20 ppm when I last tested it on Friday and added enough CYA to boost it to 30 ppm.
    Also does anyone else know any other "corrected" readings that pool store tests use? Someone in another thread mentioned something about corrected pH the other day?
    Ike
    p.s. they also show hardness at 80 ppm and suggest adding 60 pounds of "water hardness", first off I have a vinyl pool, second off my hardness test last weekend showed a calcium hardness of 160 ppm, you have to love pool stores, they also wanted me to add enough CYA to boost the level by 35ppm, imagine that recipe for disaster
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Pool Store testing terms?
    All good reasons why I do my own tests and never believe anything from a pool store. While I still go there for some equipment related things and the occasional jug of MA, nothing to do with water chemistry or chemicals is ever discussed with anyone there.
    chiefwej
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Me too, but I did not think it was worth it to invest in an Iron test kit for a single check, I will plan on taking a sample to a different local pool company to double check the iron results though.
    Ike
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    cyaf-t10039.html?hilit=cya%20correction%20alkalinity
    No idea what any of this means though.....pool stores suck whales butt!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    So basically they got the TA wrong also
    Jul 2011
    Eastern Ohio
    7,075
    Wish I could say.....That thread lost me.
    But I'd bet yes.
    Yes, they got the TA wrong. The correction always lowers the TA below the original reading, so they thought that TA was above 107.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The truely sad thing about it is, This was from the relativley GOOD pool store in the area
    May 2009
    Dallas, TX
    782
    ABCs of Pool Store Terminology
    FC - Screw Customer - Customer is a cash cow for corporate profit.
    pH - Push Hard - Pool chemicals are bought in a pool store, food comes from the supermarket.
    TA - Total Bum - Pat response whenever customer mentions the word "bleach".
    CH - Create Habits - Backwash weekly, shock weekly, eliminate phosphates, algaecide for "chlorine lock"
    CYA - See You After... - Our advice fails miserably.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by Beez
    TA - Total **** - Pat response whenever customer mentions the word "bleach".
    If you ever make a bumper sticker out of the above, I'd like to buy one.
