Thread: Small leak from a light?
    May 2012
    Elk Grove, CA
    60
    We put 5 Savi Melody lights in our new pool (first time pool owner). At the equipment pad, one of the 5 conduits for the lights has filled with water and is (very) slowly spilling over, so there is a small wet spot on the concrete around it.
    Talking with the installer, his take was that it is "impossible" to seal around the lights, and the lights are self contained so they don't need any more sealing. In his mind, the only issue is that the conduit was cut off to low so its below the water level (otherwise it wouldn't spill out). This doesn't seem right to me. None of the other 4 light conduits have any water in them at all.
    Is this something I should be concerned with? If so, what is the resolution I should be looking for from the installer? Can he pull out the offending light and seal it even with water in the pool?
    16k gal IG pool with SWG and DiamondBrite finish
    Pentair Intelliflo pump with 520 sq ft cartridge filter
    38,262
    Re: Small leak from a light?
    Well, I sort of agree with the installer. It is not uncommon for the light conduit to be full of water (they are kind of designed that way) and that is why there are the deck boxes for making the electrical connections with the lights. None of the conduit pipes should have been cut below the water level for this very reason.
    I am not familiar with these lights, but it may be possible to epoxy the conduit on the pool side to prevent water from entering the conduit (assuming they have a niche that the light fixture is mounted too.
    May 2012
    Elk Grove, CA
    60
    Good to know. The leak is probably coming from the light in the spa where the water level is 18" higher. The installer just capped the end of the conduit, so I think I'm good to go.
