Thread: Pump & Filter Placement Question
    May 2012
    Gulfport, MS
    59
    I am trying to stay ahead of the installation here and have a question. I am going to pour a concrete pad for my pump and filter. I won't get my pool till this Sat and I want to go ahead and lay the pad. I know where I want the pad, but what distance should I put the pad away from the pool without having the pump and filter yet?
    30'x54" Round Vogue Simbio AG ~21,000 gallons
    Pentair Sand Dollar SD 60 w/ Pentair Dynamo 1.5 hp Pump
    Vinyl Uni-Bead 25mil Liner
    Perfect Bottom w/cove
    Taylor K-2005 & K-2006 Test Kit
    30,432
    Re: Pump & Filter Placement Question
    Hey,
    Put it where it is functional and aesthetically pleasing to you. The horizontal distance from the pool is (almost) not relevant but the vertical distance above or below the water level of the pool is very important if your pool is an IG. If this is an AG pool, the installers may have limitations on the amount of pipe they have....check with them.
    22,553
    Put it where you want it. They should run 1-1/2" hard pipe to that pool and I'd make them bury it between the pad & pool. In fact, that's what I did!
    May 2012
    Gulfport, MS
    59
    Bury the pipe? Myself and some experienced AG pool neighbors are installing the pool
    22,553
    Yes, bury the pipe. And since it's you and neighbors all it'll cost you extra are a few
